11-Garnet
Creo 7.0 sketcher constraint color, black on dark background
Using Creo 7.0 as of today, I use the dark per-Wildfire dark background, the sketcher constraints appear black on the dark background, they appear light colored when I hover over them, is that the intent?  Sketcher appearance is grayed out so I'm unable to change the constraint color.  Is PTC trying to force people to use the default/light background???
if I set Creo 7.0 Dark Theme I can see following "picture".
If you are using Custom theme (system colors file) defined in the past then you have to define a new one.
11-Garnet
Yes, I was using the below colors, set in my config.pro, I'll try the dark theme.
system_background_color 256 256 256
Thanks, Tom
6-Contributor
You can also add  "sketcher_pre_creo4_constraints yes"  to your config.pro
This will use the classic constraints. Sketcher appearance will not be grayed out.
We just updated to Creo 7 recently, and some of our users were having this issue.  I was able to resolve it for them with a simple edit to their syscol.scl file.  Edited the first line to read "COLOR_SCHEME 0".  Affected users had "COLOR_SCHEME 7" there.  So was able to resolve the glitch without having to change the color scheme they've become accustomed to.
