Creo 8 Freeze
  • July 26, 2022
  • 4 replies
  • 2449 views
When click on symbols, balloons on drawing or weld symbol in the 3D annotation, Creo 8 is freezing and I have to "End Task" to close Creo and re-open.
My colleague open the same drawing and they have no issues.
Could be a config issue on my PC?
Thank you,
Best answer by Victor1970
I deleted cache folder, my workspace and I added the server. Now it is working, no issues.
Thank you,
StephenW
You can check your config.pro(s) by temporarily removing (or renaming) and restarting creo. If the problem goes away, you then know it is a config problem.
This could also be an odd graphics issue. You can temporarily add the config option graphics win32_gdi and restart creo. If the problem goes away, then it is a graphics issue. Remove the option and update or find a graphics card driver that works.
Hi Stephen,
I am working remote on a VDI, I sent a request to IT and wait for response.
I will let you know.
Thank you,
Victor19701-VisitorAuthorAnswer
Thank you,
