Creo 9.0 Cross Hatching showing Cosmetic Threads
I solved this myself but it was by pure accident.
My section view was showing cosmetic threads and i couldnt' figure out why.  i would recreate the section view and it would still show them.  Not every section view shows cosmetic threads, only a certain one.
What i learned was that if you have an EXCLUDED COMPONENT in the Hatch Bodies then it will show the cosmetic threads in that cross section(despite not being on that plane).  I had to turn off my excluded body and then the cosmetic threads would disappear.  What made this harder to understand was that if you have a partial view of the view you're using and that EXCLUDED BODY isn't in the actual splined area then you don't get the option to TURN ON the EXCLUDED COMPONENT.  I had to undo my partial view, make the exlcluded componented INCLUDED and then re-do my partial view.
just an FYI since my google-fu turned up nothing on this.
Bug Report?
