.CREO added to Solidworks file
Once I open a Solidworks part and make changes, when I save it there is a .creo extension added. How do I cut this off? I do not see it in data exchange.
File > Open action related to non-Creo model always results in creation .creo file. Maybe you can use File > Import command (simply switch Open button to Import button using small triangle.
I will try that, but spreading it across an entire organization will be tough. Some are having the files cause Creo 7 to crash.
