Creo Cabling - terminator table values with spaces
I have question if is possible in terminal table to use value with spaces.
Example:
| SET                         |
| PIN                          |
| DESCRIPTION       |
| Receptical 2.8 JPT |
I would like to get values with spaces in tables.
Or is it only solution to use underscores instead of spaces?
Thanks for answers,
So
BillFAnswer
We are using Creo Schematics 4 F000 and have spaces in a number of fields of our terminator table.
SET SET SET SET
PIN PIN PIN PIN
wire_gauge_range notes Crimp_to material
22-20 / 0.35-0.50 Orange Seal SEAL & WIRE
TIN BRASS
The field names don't have spaces but we use them in the data.
It may depend on what version you have.
BillF15-MoonstoneAnswer
SET SET SET SET
PIN PIN PIN PIN
TIN BRASS
Jaime_Lee
Community Manager
December 31, 2019
@thano   Did @BillF  answer your question?  If so, can you mark this as an Accepted Solution?
