Creo Cabling Wire default name
I am using Creo Parametric - Release 4.0 (connected) 4.0 M050
Is there a way to define default Creo Cabling wire name parameter?
New wires had W0xx now have w-xx default names.
    Hi @IAircraft_25,
    There is no parameter to change the default naming convention of a cabling wire. You need to manually change the parameter names by going to Parameters in Route group in Cabling tab > Select a Cable/Wire/Ribbon > OK > select the name and type the new name in value column > Apply > OK.
    Amol
    Hi @IAircraft_25,
    Amol
