CREO Distributed Batch run fail
I am using Creo Parametric Release 8.0 and Datecode8.0.3.0
I used CREO Distributed Batch to run DXF export mapkey task but keep failing, I've confirmed there is no any Creo launch initialization dialog box pop-up when running CREO client and I tried both default export task type and my mapkey they all failed. I don't see any log file generated. I ran my mapkey manually and it did work successfully
    1.] I do not understand why you start ptcdbatch as Administrator. Run it as logged user.
    2.] I suggest to not use One drive directory ... move configuration to standard local directory.
    Hi Martin
    Same result when run it as logged user and switching to other path
    Peter
    Hi
    did you try and run trails instead of batch processing a mapkey instead ?
    like :
    "C:\Program Files\...\Parametric\bin\parametric.bat" -g:no_graphics -batch_mode trail.txt
    Maybe give a try to the above with one file and then serialize it with a scripting tool.
    My two scents.
