Creo Drawing Symbol Path
I use Creo 8.0.2.0
I have some symbols to update on drawings..
On some drawings the symbol name is "symbol.sym". In that case I can select a symbol directory (Annotations\Define symbols\Symbol Dir) and update the symbol.
On some drawings the symbol name include the path. In that case Creo search in the path included in the name and doesn't consider the directory defined from Symbol Dir. (even if the path no more exist).
Is it possible to remove or break the link to the old path associated to the symbol name ?
