11-Garnet
Creo drawing table fix
I am using Creo 9.0 and i want to fix the position of bom table in creo drawing which is created through format (.frm).
11-Garnet
Thank you 🙂
please explain what you mean with "I want to fix the position of bom table in creo drawing".
11-Garnet
I have a customized format file (.frm) that I created, in which I have created tables for some information. Now,  when I use that format in drawing, those tables can be moved from their original location. So is there anything I can do to fix their position?
when you load format to drawing then Creo copies bom table from format to drawing. Therefore it is not possible to "freeze" bom table location.
