CREO drawing views: how to change from the american system to the european system?
  • October 31, 2015
  • 4 replies
  • 7358 views
I would like to start expressing my drawing model views according the european system. Do you know how I can change from the american system to the european system?
Thank you
Vasco
Best answer by mpeterson
Change the detail drawing properties of the "projection_type" from default 3rd angle to 1st angle.
mpeterson1-VisitorAnswer
vcarvalho1-VisitorAuthor
Thanks for tip Mark. True, but that will only change the projection type of an open drawing. My idea is to change that permanently so that I don´t have to do it every time I creat a new drawing. Hon can I do it?
Regards
Vasco
Change it in the Detail Configuration file (prodetail.dtl). This will probably be in your Common folder within the PTC program files. This is the file you can change many of these settings so they are the default settings in any new drawing.
