CREO - Driving dimensions from note parameters
I have created a new paramter and set to to the 'note' type.
how can i use the alphanumeric values entered inthis note to drive relations.
for example, my note says SL125A
I would like an IF syntax that returns a numerical value when this is entered.
IE
IF PARAMETER_1 == SL125A
PARAMETER_2 = 15
ELSE
PARAMETER_2 = 1
Can anybody help?
I tried putting */ , ' , and " around the note value but none of these worked.
when using ' and " the error message read
error Left and right sides are incompatible
What does this mean?
