Sep 26, 2022 1:59 PM UTC
CREO freezes at every click/operation
I am using Creo Parametric Release 5.0 and Datecode5.0.5.0
At every click/operation the program freezes for minutes.
This make it not useable at all.
It seems like the program is trying to reach/verify the floating licence at every operation.
Sep 26, 2022 2:41 PM UTC
What are your computer specs, memory, graphics card, OS, etc.
Is Creo installed locally or on a network drive?
Are you using a PLM system?
Sep 26, 2022 2:45 PM UTC
This issue started suddently one day ago.
The computer specs are not relevant in this case, since we are facing the same issue  on different computers along the office.
We are using Windchill, and it works fine when used on a web browser.
The software is installed locally on every station, but the licences are situated on a delocalized server (floating licences).
Sep 27, 2022 1:30 PM UTC
1.]
Add following option into config.pro using Notepad and start Creo.
graphics   win32_gdi
2.]
Try working with Creo. If problem disappears then it is caused by graphic card drivers.
Remove graphics   win32_gdi option from config.pro.
Uninstall current drivers.
Install older drivers.
Test Creo.
Disable automatic driver update.
