Creo Harness Package not showing Center line for wires
When I switch over to centerline mode in the harness package the center lines are not shown, however when I hover over them they highlight... any suggestions how to get them to show? I cant right click and edit to add a location to the segment in this manor, which is frustrating. I used to be able to see them at one point.
When using show as thick cable it shows the cable without issue.
I have found it to be a new config.pro setting I added "shade_with" I had set to no
Community Moderator
Hi MB_4413469
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
