Creo install error
I'm trying to install Creo 11.0 Student Edition, but I'm stuck at the license step in the Installation Assistant.
After I enter the product code **BE110908EDSTUDENTEDK12**, it says "Success!" — but in the "License Sources" section below, the generated license file shows the following error:
**"Bad file or format"**
(C:\ProgramData\PTC\Licensing\BE110908EDSTUDENTEDK12_license.dat)
Because of this, I cannot proceed with the installation.
I’ve already:
- Disabled my antivirus software (including Alyac)
- Deleted all previous files in the `Licensing` folder
- Run `setup.exe` as Administrator
- Tried restarting the process from scratch
Could you please help me resolve this issue, or let me know if I can manually download and register the license file?
Thank you in advance!
Try contacting directly - academicsupport@ptc.com
you can request license file via email. Please read https://community.ptc.com/t5/PTC-Education-Forum/Creo-Parametric-9-0-Student-Edition-Licence-error/m-p/897846 discussion.
Emeritus
Hello @정차_13799312,
It looks like you have some responses from some community experts. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
