Creo Installation
  • November 8, 2016
  • 4 replies
  • 2500 views
Hello!
I Downloaded Creo for school use. I have a problem at installation. The installer stops working at the step where it verifies the licence. I downloaded Creo 3.0 64bit version. I have Windows 10. I tried running as admin and in compatibility mode. This problem is not only on my PC. I have several friends that have the same problem.
Thanks in advanced for any help!
what is the size of downloaded file ? Did you unzip it ?
MH
ddavid-21-VisitorAuthor
The size of the downloaded zip file is 3.82GB. I unzipped it and in the folder there are 3 exes: setup; setup-schools; setup-trial. I ran the installer setup-schools and I get to this screen with "Please wait while we retrieve your licence" and then it just stops working. The only solution is to force close the setup.
Imgur: Images with errors.
Your problem can be related to network card MAC address. Maybe installation is not able to get your network card MAC address.
I can check network card status for you, if you publish contents of ip.txt file created by following command entered in DOS prompt window.
ipconfig  /all  > ip.txt
Also check what files are save in C:\ProgramData\PTC\Licensing directory.
MH
Hello! Sorry for responding so late. In ProgramData I don`t have any PTC folder...
Here is the content of the ip.txt file.
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DIMI-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Intel(R) Ethernet Connection I217-V
   Physical Address. . . . . . . . . : 54-BE-F7-0B-8F-3A
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::846d:cd6b:bb69:48dc%13(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.101(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Thursday, November 10, 2016 2:09:26 PM
   Lease Expires . . . . . . . . . . : Monday, December 18, 2152 11:54:45 PM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 55885559
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-90-3A-AF-54-BE-F7-0B-8F-3A
   DNS Servers . . . . . . . . . . . : 192.168.1.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{FE7D1858-7AEA-4E94-95EF-65C29261E7DF}:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 10:
   Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
   IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:2cfb:bdfe:adb2:5e37(Preferred)
   Link-local IPv6 Address . . . . . : fe80::2cfb:bdfe:adb2:5e37%4(Preferred)
   Default Gateway . . . . . . . . . : ::
   DHCPv6 IAID . . . . . . . . . . . : 67108864
   NetBIOS over Tcpip. . . . . . . . : Disabled
Hope you can help me!
