8-Gravel
November 23, 2019
Creo Mouse Lag with windows 10 1903
I recently upgrade to windows 10 1903  enterprise   November   update. I got problem in both creo 5 and 6.
When the assembly is small (like single part), everything seems ok. when the model gets complicated, like 30 parts, i got sudden huge  lag when suddenly drag mouse to pan zoom.  it's not always happen,  lag for the first second, then good for a little while  . After little while, it starts lag again, i rotate the model a bit, then good again, then repeat.
The "good" period seems like it's reading cache of current model.
I also noticed both verison of creo are stongly use signle core single thread now(i know CAD is single core, but before wasn't like this).  When i rotate model now, only single thread is 100%, lag is gone when that thread is low. Now the performance is waaaaaaay lower than my Core i5  6600 with nvidia gtx750.
No lag with manual click Pan Zoom under "Zoom" tab, no lag with mouse movement on screen(like i could play games...), just model lag when manipulate with mouse.
system is windows 10 1903 build 19025.1051, intel 5960X@4.3ghz, 56gb ram@2400mhz, Firepro w9100, monitor 1080p.
Creo are  6.0 M010 and  5.0 M040.
Thanks.
gchen-28-GravelAuthor
8-Gravel
November 23, 2019
unable to upgrade to newer creo for now. Did try reinstall or play with BIOS.
8-Gravel
November 24, 2019
update :
Temporary switch to Group B in AMD Radeon GPU driver Platform Compatibility.
Current driver version for Firepro  GPU  is 2019 .Q4, Known issue happens same on 2019.Q3 and 2019.Q3.1
With Group B setting,  i think i lose all GPU feature like SuperSampling , ECC GRAM,  8xEQ Anti Aliasing....
the following recommendations are "without guarantee".
1.] set following config.pro option temporarily and test Creo behaviour
graphics  win32_gdi
2.] it seems to me that W10 "big" update can "corrupt" graphic card drivers,
therefore I am suggesting uninstall/restart/install graphic card drivers
8-Gravel
November 25, 2019
Hi Martin,
Thanks for helping !
however, win32_gdi wont help that lag, tried before post.
driver refreshed/upgraded, not work.
also tried
use_software_opengl yes
graphics win32_gdi
spin_with_notes to no
spin_with_silhouettes to no
display_silhouette_edges to no
edge_display_quality to normal
shade_quality to 3
shade_with to no
none of works.
Any idea?
my tips follow:
1.] uninstall 1903 update to see if the problem disappears
2.] report the problem to PTC Support
No other ideas 😞
