Creo Parametric 3.0 M040 *.UI file
  • September 29, 2015
  • 2 replies
  • 1173 views
Please can any one  send me the default original *.UI file for Creo Parametric 3.0 M040 . which contains the original tools on creo default layout. It will be better if schools tab is added. Also mention steps to set it as default.
18-Opal
September 29, 2015
Hi Azim,
Is this regarding the Student Edition of Creo Parametric?
Amit
Azim,
As mentioned in an earlier thread Creo Layout Changed (Tools/Tabs) we can not help unless you provide more information.
The creo_parametric_admin_customization.ui and/or creo_parametric_customization.ui files is what you are after.
Not knowing your arrangement, you may want to try the following
  • check your recycle bin for a discarded copy
  • check to see if there is a server version.
  • copy an associates creo_parametric_customization.ui file (that has what you want) and place it in your start up directory
  • rename the creo_parametric_customization.ui file in your start up directory to creo_parametric_customization.old and restart creo to see if it returns
Ron
