creo parametric 4.0 importing sldprt file
I am trying to import a SLDPRT file into parametric 4.0 and every time I try creo locks up any ideas?
Dale_Rosema
Check out this link:
https://community.ptc.com/t5/Data-Exchange/Does-anyone-know-how-to-open-a-Solid-Works-solid-model-in-Pro-E/m-p/215622
I search on sldprt to come up with this. You can see if there are other article that would be more helpful.
the version of Solidworks in which the model was created plays a role when importing. Then you have to know whether your Creo 4.0 version is able to import models from this Solidworks version.
