Creo Parametric 9.0 Will Not Allow Drag/Drop Open File From Windows File Explorer
In previous versions I had no problems opening Creo Parametric model files by dragging and dropping them into the graphics window from Windows File Explorer.  Now this function to open files does not work at all, not for part models and not for dragging part models into an assembly.
What changed in Creo Parametric 9.0 that this function will not work??
Hello  tfilipiak,
In Creo Parametric 9.0. drag and drop is working for me for Creo files in part as well as in assembly mode.
If you are using any config file, can you check drag and drop by removing config file
Hello  tfilipiak,
tfilipiak10-MarbleAuthor
I removed the config.pro file from the folder and I still cannot drag and drop parts into Creo for the model or for an assembly.
What version of Creo 9 are you using?
