creo_parametric_customization.ui location
Pros/Creos,
Just switched to Creo 2.0 from WF-4. I want changes I make to the interface saved to a creo_parametric_customization.ui in a directory that I set not the working directory. There must be a config option to set the location I want. What config setting do I need to use?
Thanks!
Bill Watkins
Sandia National Laboratories
Mechanical Design Dept. 2998
PO Box 5800 MS 1172
Albuquerque, NM 87185
505-845-9666
Thanks!
Bill Watkins
PO Box 5800 MS 1172
505-845-9666
