CREO Parametric: Drawing flexible component such as hoses and cables with their real behavior
Hi everyone.
Is there any option in CREO Parametric,  to 3d-draw flexible components such as hoses and cables after their natural properties such as weight stiffness tension rotation etc.?
I want to draw some water hoses in a machine, so that the hoses can behave after their real structural propertires, not only forces by my restrictions.
Thank you so much in advance for your help.
Br,
Hasan
tbraxton
tbraxtonAnswer
 The short answer is no. In theory one could use the analysis and simulation tools to do what you propose in some cases, but it would not likely be worth the effort required to get any level of fidelity.
If you did want to do this the best option would be to use the BMX module and FEA to get the "true" geometry of a loaded hose or cable.
tbraxton
tbraxton22-Sapphire IIAnswer
Thank you so much for your express reply. Very helpfull. 🙏👍
