Oct 28, 2026 6:09 AM UTC
Creo Parametric Drawing: Restrict Section Arrows to the Correct Parent View
Hello PTC Community,
I would like to know if there is an option in Creo Parametric to restrict the placement of section arrows to the appropriate parent view in a drawing.
Consider a drawing sheet containing three projected views and a sectional view created using a datum plane. To indicate where the section is taken, I use the Add Arrows functionality to display the cutting plane and its direction on the corresponding parent view, for example, Section A-A.
However, Creo also allows me to place the same section arrows on another projected view, even when that view is not the intended reference view for the section. From a drawing standards and documentation perspective, this can lead to incorrect section representations and confusion.
My question is: Is there a configuration option, drawing setup setting, or other functionality in Creo Parametric that restricts section arrow placement to the correct parent view and prevents users from placing the arrows on unrelated or inappropriate views?
Ideally, Creo should identify the valid view for the selected section and allow the arrows to be placed only on that view, thereby helping maintain drawing consistency and compliance with drafting standards.
I would appreciate any suggestions, workarounds, or configuration options that could help achieve this.
Thank you!
Oct 28, 2026 9:48 AM UTC
Consider a scenario Where you have placed three views namely Front, Top and Right.
You need view Section A-A on the right view.
Technically, the arrows can be placed either on the Front or on Top View. Both are appropriate views for Arrow placement. Hence, Creo expects you to choose the view where you wish to place the arrow.
Knowing, what we know is just a fistful of Earth, brings in humility.
Oct 28, 2026 11:21 AM UTC
Hi Srinivasan,
Yes, I agree. But in a scenario where a few of unexperienced CREO users tend to mark the cut section on a different view, the manufacturer gets confused. Hence, if there’s an option on Creo that I can use to block the other views so that the cut section can only be placed on the correct drawing view, it’d be easy for us & my team.
Can you/anyone please suggest if there’s an option that way?
Oct 29, 2026 3:23 AM UTC
That requires standardized Drawing Creation.
Let us say that the FRONT view of the Part is the DESIRED Front View in the Drawing.
In such a case one can create Templates (different from formats) and define the required views including Isometric in the drawing, Show Driving Dimensions, Sections and Arrows in the defined view. When the template is used for drawing Creation, it would automatically, populate the views, section views, section Arrows, Dimensions and even do a Cleanup Dimensions on the drawing. In the case of an assembly drawing, the template created for the assembly can populate the BOM Table, Exploded views and Ballooning.
One can create different templates for different types of drawings. In such a case one can include standardised Notes that are relevant to the type of part too.
This requires standardized method of model creation.
Catalina
Community Manager
Nov 12, 2026 3:16 PM UTC
Hi ​@SharmaKona-Adro ,
I wanted to see if you got the help you needed on your post:
If so, please mark the appropriate reply as the Best Answer or please feel free to detail in a reply what has helped you and mark it as the Best Answer. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Best regards,
Catalina
PTC Community Manager
Catalina | PTC Community Manager
