Creo Parametric - Sketched form issue
Hello PTC Community members,
Currently I am struggling with Creo Parametric during working on Sheetmetal part.
Once I want to create second sketched form on the same surface, next to each other, Creo suddenly crashes and I cannot open my 3D model anymore.
Did this happen to anyone? Is this some bug, or?
mvajlaAnswer
Hello Martin,
I think I already recognize the issue.
When I use a sketched form together with one UDF and then edit that form, the Creo crashes. It is probably caused by UDF defined in much older version (Pro/E) of Creo than we are working now. I will try to redefine complete UDF group if it will help.
Here you are on the "Creo Elements Direct Modeling" which is a different CAD product of PTC. You should move your post to "Creo Parametric" to have a better chance to get help.
Currently I am strugling with Creo Parametric during working on Sheetmetal part.
please Creo file for testing purposes. Also include some picture showing your situation.
mvajla13-AquamarineAuthorAnswer
Hello Martin,
