Jun 21, 2022 4:20 AM UTC
CREO Piping library for Fittings---unable to access using 3 link files
I am using Creo Parametric - Release 8.0 (connected) Release 8.0 and Datecode8.0.1.0
I found CS115015 outlining how to obtain a Piping Fitting library. There are 3 links shown with the instructions to download each link, add it to a single directory and then unzip the first file (.001).
After downloading all 3 files, adding them in a single folder there is NO option shown to EXTRACT or Unzip the first file. Windows 11 does NOT recognize the file as a zipped file.
I am obviously missing something??
    Jun 21, 2022 7:31 AM UTC
    you can use 7-zip application to unzip downloaded archive.
    rbc1-VisitorAuthor
    Jun 21, 2022 5:54 PM UTC
    Hello Martin,
    Thanks for your input---it WORKED.  I had tried the Windows Extract tool and WinZip with no luck. 7-zip did the trick.
    RBC
    Jul 27, 2022 5:20 PM UTC
    I cannot download the files from those links. Is there a different location that they can be downloaded from?
    Jul 27, 2022 5:49 PM UTC
    I was able to download 3 zip files, no problem.
    Jul 27, 2022 6:03 PM UTC
    Company firewall rules do not allow us to download zipped files. 😞
    Guess I'll have to do it home, burn a CD and bring them in tomorrow.
