Creo Schematics 1.0 Lite Routing Problem
I am new to Creo software and have been given the task of recreating some wiring diagrams used for assembly in Creo Schematics. The entry is manual and I am using the minimum "smarts" just to make the diagrams look good. Everything is coming together nicely but when I route fibers the route command seems to have a mind of its own and completes the connections in a less than desirable appearance. I have to terminate routes to attain halfway decent looking lines -- which isn't the right way to do it. How can I control how fibers are routed in Creo Schematics so I don't waste so much time on aesthetics?
Linda
