Creo Schematics 10.0.0.0 data table/ report table is no longer modifiable
when a data table is created within a schematic via; generate report, and the drawing is checked in, the next time the drawing is checked out and the table is needed to revise then it is not possibble to open the table with the error "error<<<<< Unable to read table data file" despite the table being clearly visible/readable within the schematic,.  If an old version schematic is opened (ie V4) then then upon opening in schematics (V10.0.0.0) it is possible to modify once.  Bug alert!
are you referring to table on the sheet  ?
do you see it only when working with windchill ? or also when saving to the disk ?
did you try to check in different design ?(maybe the design is corrupted) .... i don't face this issue in Creo Schematics 10.0.0 .
pwailand10-MarbleAuthor
Yes our procedure is to check the drawing into windchill.  It happens with every design (50 plus tested so far)  this did not occur with schematics 4 or 7.
6-Contributor
Hi Pwailand,
This is an issue that we found with WNCBridge RC16, we have an update WNCBridge RC16_11 that should resolve this issue.
Please contact me on kieran.gilhooley@virtual-interconnect.co.uk and we can setup a meeting to help.
Kind Regards,
Kieran
