6-Contributor
Creo Spec Driven Piping
I need copy a spec driven piping assembly that is repeated a dozen times in my design. The only difference is the component PID numbers such as the valve numbers will be different. Is there a way to change or add these numbers after I have copied the piping assembly?
Community Moderator
Hi @KenMeeler,
Thank you for your question.
Anurag
