Creo View: "Restore Location to Saved", but in another Annotation Set?
Hello Community,
I would like to restore the location of a part, or all parts, as saved in one Annotation Set (using the Capture Location command) into another annotation set (using the Restore location command when the other Annotation Set is active).
However, this does not seem to work. Is it really the case that saved positions are deleted as soon as you switch to another Annotation Set?
