CreoParametric 11/12 compatibility to SolidWorks 2025?
We would like to update our MultiCAD environment to a newer Creo version 11/12
CS134024 shows that Creo 9 has compatibility to SolidWorks 2025 in Version 9.0.12.0.
When does this support comes in Creo 10/11/12 ?
We have a multiCAD environment and this holds us back to upgrade from 10 to 11/12.
Marc
    Hello Marc,
    Please note that SolidWorks 2025 will be compatible with the following Creo versions:
    • Creo 12.4.1.0
    • Creo 11.0.6.0
    • Creo 10.0.10.0
    • Creo 9.0.12.0
    You may plan to update Creo once these releases are available.
    KenFarley
    Is it documented somewhere that the newer versions of Creo don't handle the same releases of SolidWorks as version 9.0.12.0? I would imagine newer versions of Creo would be able to accommodate the same or later versions of SolidWorks, but it is most definitely NOT something I can find any sort of documentation about.
    Perhaps someone with more knowledge than I will be able to point you to some sort of table or release notes that gives actual info about this topic.
    boemi14-AlexandriteAuthor
    CS134024 documents this in detail for every format and Creo Version.
    Swx2025 ist just specified for Creo9.
    according to https://support.ptc.com/cs/release-calendar/index.html?productFamilyIdList=2&productIdList=30 page
    • 9.0.12.0 ... release date = Q1 2026
    I hope that also in Creo 10.0, 11.0, 12,0 released in 2026 SolidWorks 2025 file import will be implemented.
    • 10.0.10.0 ... release date = Q1 2026
    • 11.0.7.0 ... release date = Q1 2026
    • 12.4.3.0 ... release date = Q1 2026
    Note: It is necessary to monitor CS134024 regularly.
    Hello Martin
    Thank you for your reply.
    I hope this is the case and they just missed to add this as a note to the newer Creo versions.
    Yes, I check CS134024 every 3 months.
    Have a good Day
    Marc
    Hi @boemi
    Your questioning is fair. In article CS134024, red item highlights recent updates and the Creo 9.0 updates are more recent than that of Creo 12.
    The most efficient choice here is to click the portlet Something is wrong in this article.
    This will fire a process and notify the authors of the article directly.
    Hello Marc,
    • Creo 12.4.1.0
    • Creo 11.0.6.0
    • Creo 10.0.10.0
    • Creo 9.0.12.0
    PTC contacted me yesterday and provided the same information.
    The CS134024 is now up to date.
