Sep 23, 2022 8:41 AM UTC
CSV table separated by commas and not spaces
I have been trying to add an excel table into a creo drawing and when I import the csv file into the drawing the data is separated by commas and I get only one-column table. Does anybody know how to fix this so that I get all the columns and a table that looks like to one I have in excel?
Thank you for your help.
Sep 26, 2022 1:53 PM UTC
@BC_10219589 wrote:
Thank you for your answer, however, I can't paste excel cells into my creo drawing (I am using Creo 7, 0.7.0)
do you know why this happens?
Thank you,
did you apply setting from https://www.ptc.com/en/support/article/CS355947 ?
Creo 7.0.7.0 & Excel 2016 on my PC works as expected. See video.
Sep 23, 2022 11:25 AM UTC
on my PC I applied setting from https://www.ptc.com/en/support/article/CS355947 .
In Creo 9.0.0.0 I am able to:
  • create empty Excel workbook in Creo drawing
  • open Excel file outside Creo
  • select cells
  • CTRL+C
  • double-click table in Creo drawing
  • CTRL+V
I do not need to export/import csv file.
Sep 26, 2022 1:44 PM UTC
Thank you,
Thank you,
