Ctrl+z is not working
My Ctrl+Z on creo7.0 is not working, it stays grayed out and does not allow me to undo any steps.
tbraxton
tbraxtonAnswer
Do you have any Toolkit or other Creo API customizations loaded in your test environment? If so this can cause problems with undo functionality. Even if you do not have company API programs loading you may have it due to use of 3D mouse for example (3D Connexion). If so, create a test environment that does not have any customization via APIs loaded.
Articles:
LeandroSD10-MarbleAuthor
Thank you, my friend, but it didn't work.
what do you want to achieve with CTRL+Z ?
I want to undo some action in a part or assembly. For example: undoing a command that I made, or reverting an action in an assembly
unfortunately your answer is worthless. Please do simple test:
  • create new part
  • create Extrude feature
  • modify one dimension
  • press CTRL+Z
Does CTRL+Z work well ?
tbraxton
tbraxton22-Sapphire IIAnswer
Thank you very much, I stopped the toolkits and the command started working normally again. Thank you very much, my friend.
