2-Explorer
April 27, 2015
Custom Symbol issue
  • April 27, 2015
  • 4 replies
  • 1584 views
In BOM table's repeat region of creo drawing
file, I have set relations using user defined parameter (udp). I am trying to
create a custom symbol which takes udp into it. Value of udp is not populated
once I use custom symbol
” has been created.
Regards
Ketan
Best answer by Chris3
Put this in your symbol:
\rpt.rel.YOUR_USER_DEFINED_PARAMETER_HERE\
2-Explorer
April 27, 2015
In other words, I would like to add variable text of symbol as user defined parameter of repeat region..
Chris3
Chris321-Topaz IAnswer
2-Explorer
April 28, 2015
It is required to be set in variable text or simply in the name?
