Customize Existing Table
We have the full version and I have a fully custom library of fasteners. I am looking to 'add' the pem nuts to our catalog. To back up a bit, in our current offerings, I am using fields <BUW_NAME> & <BUW_SIZE>, I created a relation to combine these two fields under the parameter <DESCR>. This parameter is what we show on drawings/ BoM's.
So, I added/ created fields <BUW_NAME> & <BUW_SIZE> to a Pem Nut table and generated data under each column. What I am trying to do is get these table fields linked inside the models parameter table. The goal here is to insert a single instance (AC-M6-2) in to an assembly file, and the assy dwg (BoM's) would show:
PART #      QTY.   DESCRIPTION
AC-M6-2     1        PEM NUT, M6
The 'DESCRIPTION" column on the dwg table is linked to our model parameter <descr>. This is the relationship I am attempting to create by adding columns to the provided tables.
Not having much luck, so what am I missing?
OliverGräbner
Hi, can you send me your *.dat file and the pem template part. Then I will have a look to it.
The steps you describe look good. So I think it is only a minor problem.
Do you want to create new pem nut parts or do you want to reuse existing parts?
Oli
Oliver Gräbner - B&W Software GmbH
kboyle1-VisitorAuthor
Sorry for the long delay, I will forward/ attach the items shortly. I have a new issue I could use some expert help on.
OliverGräbner
just want to know if this problem is solved?
If yes, it would be nice if you close this topic.
Otherwise please give me a short feedback.
Oli
