3-Newcomer
Customizing Sheetmetal Bend Note
Hello, I was wondering if there is a way to make a double-line Sheetmetal Bend Note in Creo 8.0 through config.pro.
Through these discussions I found you can add the bend radius to a bend note by adding "&inner_radius" to "smt_bend_notes_order" in the config.pro, but this makes the note long and often difficult to work into my drawings.
Is there a character that can be added to a config.pro string that forces a newline?
For example: smt_bend_notes_order &type&direction&angle \n R&inner_radius
What it looks like:
What I would like:
please ask PTC Support directly. I guess requested functionality is not implemented.
