Cutting away part of section view to see what is behind it in the same view
  • November 6, 2018
  • 4 replies
  • 3116 views
I am trying to cut the corner away from a section view to see a screw that is underneath it, in the same view. I do not want to create a separate view. I don't care what is on top of the corner, I want to see the screw that is underneath it, while still seeing the top of the rest of the board I am dealing with. Please help.
    Best answer by MartinHanak
    create Local section instead of Full.
    ngraham951-VisitorAuthor
    Thank you so much. Could not for the life of me figure out what to call it so could not find anything on google. Is there a way to create this local section with straight lines, say a rectangle, instead of using a spline?
    as far as I know spline as a border is the only one option.
