Cylinder with a hole / two insert mates
- 13 replies
- 9818 views
- Translate All
I have a little dilema. I have two cylindrical surface that are mated together by their outside surface using a insert mate. Then I align the parts again by using another insert mate to line up bolt holes. This totally defines the mate (i.e. turns it yellow) as you can see on the drawings. If thing don't line up quite correctly, I hit the flip icon to properly get them to line up.
I made a couple of changes and went back into my part to find that the part didn't line up correctly any more. When I flipped it, you can see the results on the second picture. Do I need to add a third mate to get this to stay as needed?
I ended up removing one surface from each mate (the one belonging to the assembly not the part being assembled) and used the move/roate to change the orientation of the part and rechoosing the surface to get it to turn out correctly (see the third picture).
Any input as to:
1. Why this may have happened.
2. Why can't it be correctly simply - without having to break the mates and rechoose the surfaces)
3. If you should always add the third mate to prevent thes from being changed (the part actually isn't actually fully restrained when there are two solutions to the mate)
Thanks, Dale
