DEF_DENSITY no longer works in Creo 8
Hi there,
My company updated to Creo 8.0.1.0 some weeks ago. Now it turns out, that the model check test "DEF_DENSITY" does not work anymore in Creo 8.
In Creo 8 every part gets the default material "PTC_SYSTEM_MTRL_PROPS", which has the density of 1.0.
The test DEF_DENSITY should check, if the density is 1.0, but the test passes.
Since we use modelcheck as a gatekeeper for our windchill, there is a pretty chance, that the pdm-system gets filled up with neutron-star-like parts.
Does someone knows a workaround?
MatAnswer
ok, I think I found a workaround.
In "checks.mch" I added this line:
PRT_DENSITY YNEW E E E E E
In "constant.mcn" I added the some boundaries for the density:
DENSITY_LOW 0.000001
DENSITY_UPP 0.9
Looks promising for now.
Mat16-PearlAuthorAnswer
DENSITY_UPP 0.9
I'm glad you solved your problem.
Hi Mat,
I was looking around for a ModelCHECK setting that flags this as well and just stumbled upon this article today: Article - CS378862 - ModelCHECK check DEF_DENSITY is unable to report error/warning in legacy parts with assigned density as 1.0000 (default) and no material. (ptc.com)
I figured I'd post here as well in case other people are searching around for the same thing.
