6-Contributor
Default hole placement type
Hello !
Using Creo Parametric 9.0.3 here.
When I am creating a hole, the default placement type is Linear.
Is there a way to change this to something else, like Sketched ? I have looked for a config.pro option but found nothing so far.
KenFarley
KenFarleyAnswer
In the past, when things like this come up - wanting a default behavior for which there is no configuration setting - the suggestion is usually to define a mapkey. Store the picks that lead the hole placement to be what you want as the default, name the mapkey something, then use that when you want to create a hole. It’s not as nice as just setting a default, but it’ll get the job done.
TomU
Creo Parametric 12.4.0.0 adds something called “Feature Presets”.  These will let you set up a default configuration for many features, including hole features.
https://support.ptc.com/help/creo/creo_pma/r12/usascii/#page/whats_new_pma/core_presets_iFQA4.html
FLOLAP6-ContributorAuthor
6-Contributor
Gives me a reason to look forward to Creo 12 !
KenFarley
KenFarley21-Topaz IIAnswer
6-Contributor
Good idea KenFarley !
Developping Mapkeys should become a reflex for me.
Community Moderator
Hi ​@FLOLAP,
Anurag
