Apr 5, 2016 3:37 PM UTC
Default part tolerance
- 4 replies
- 2898 views
- Translate All
It seems some one has changed the default tolerance on a single part so that the 3 place tolerance is +/-.001, where it should be +/-.005. For the life of me, I can't remember how to change it back. I used to be able to directly click on it in WF3, but haven't had to contend with this problem since moving to Creo 3. Normally I won't care so much, but these values are reflected in the drawing tolerance block, and the design intent doesn't require that tight of a tolerance globally. What's odd, is that it was only changed on this specific part.
