Detail/partial view generate as full view in pdf while using Creo 7.0
Hello Folks,
I am using Creo 7.0 and partial or detail view generates as full view in pdf file when working online (windchill connected). But when I generate pdf file offline (with standalone creo / offline) same view remains as is as they are in creo drawing.
I wonder if anybody faced this issue. Any help is appreciated!!
Mani
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
Catalina
Community Manager
Hi @mrajan,
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
