Die form problems
  • November 12, 2014
  • 3 replies
  • 1513 views
Hello i want to make a die form in a sheetmetal and when i constraind , i have an error
i don't now reason why creo not make this
tks
Hello Bogdan,
I've transferred your question to the Creo community. I think you'll get better responses to your problem here.
If you post the zip without the rar compression, I will have a look.
Please post a picture of what you are trying to do.
7-Bedrock
November 16, 2014
I am not sure what you are trying to do, but according to the files you put, it looks like you need to manually set the die shape surfaces ( in the Shape tab).
It is possible to set the surfaces in the form part, and then it will be set for every die form you place with this part.
You can specify these surfaces inside the form model by creating an annotation feat with form properties.
