6-Contributor
Dimension in the drawing goes missing after checkin
When I use create dimension in the drawing without checking out the CAD model, the dimension goes missing in the drawing after check-in. Why this is happening?
StephenW
StephenWAnswer
By default, created dimensions, even though created in the drawing, belong to the model. So any newly created dimensions will modify the model and you will need to check in the model also.
BUT...
There is a config.pro option,
create_drawing_dims_only YES
If you add this option to your config.pro, all dimensions created after this option was added will belong to the drawing and the model will not be changed.
WARNING: there are some things, that may be odd. In older releases of creo, GD&T created could not be attached to created dimensions when this option is on.  Some of this has been fixed with the way GD&T is done now, so depending on your creo release, this solution may work for you.
StephenW
StephenW23-Emerald IIIAnswer
BUT...
20-Turquoise
The default value for create_drawing_dims_only has been changed to yes in Creo Parametric 11.0:
https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/whats_new_pma/drw_config_value_change.html
