Dimension line extends directly through DFS symbol on diameter dimension with associated GTOL.
I am using Creo Parametric Release 5.0 and Datecode5.0.3.0
Dimension line on drawing runs directly through datum feature symbol on published PDF file, this can also be seen when the dimension is selected and highlighted within the drawing. and on published PDF file. However when if you don't select and highlight the dimension the dimension line does not extend through the datum feature symbol.
See attachments.
Here are the errors that I faced
n/a
    StephenW
    Can you add an image or something to show what you are describing?
