Dimension properties
  • October 21, 2016
  • 7 replies
  • 3513 views
Is it possible to apply the dimension properties of a previously created dimension to a new dimension or another dimension in the drawing environment? I send a lot of time creating dimensions from scratch and then going in and changing the individual properties of a dimension. Only to create more dimensions with the same exact properties, the only difference is the dimension value. It's very time consuming and redundant. Any help would be appreciated.
StephenW
If you select multiple dimensions, you can adjust the properties of all the dimensions.
talderman1-VisitorAuthor
This is helpful and a step in the right direction
I am just curious ... please can you publish what properties do you set for a dimension.
MH
I am sorry I can't provide a screen shot but basically it's:
Properties Tab
Value and Display: Decimal places
Tolerance: Tolerance Mode, Tolerance Tab, Decimal places
Display
Prefix and Suffix
These are the main fields that I am constantly editing within my dimension properties. However not limited to just these because I need to edit witness display and text orientation on different occasions also.
