Dimensioning decimal places
Hi all,
Is there a way to show how decimal places are displayed on 2D drawings?
I have the config currently set at 0 places but if the dimension is for example 21.5 i would like it to display as 21.5 and not round up to 22.
I know I can manually change the dimension it to 1 decimal place but is there a way it will auto do it?
kdirth
kdirthAnswer
Are you looking to show decimals only when there is a decimal?
Set decimal places to 1 and set trailing zeros to no.
kdirth
kdirth21-Topaz IAnswer
SteveJI10-MarbleAuthor
Hi, yes that's what i want to show.
What is the config name for the trailing zeros?
Drawing settings are stored in a separate file called a dtl file. You can access the drawing options in drawing mode. I believe the setting you want to change is lead_trail_zeros.
Check out this link:
https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/index.html#page/detail/dso_customize.html
