Direct method to define the maximum feedrate of a sequence
Defining the tool to slow down on internal corners isn't a problem. We do this when constructing trajectory passes using the arc_feed and arc_feed_control parameters
What I would like to be able to do is to limit the feedrate if it tries to increase dramatically. I figured if there was a parameter that could limit the maximum feedrate, no matter how much the tool/part geometry combination wanted to increase it by
