Display BOM position of a part in drawing as note
 I am using Creo 7.0. I have an assembly. I want to show the BOM position of a particular part in the drawing as a note. Can we extract that BOM position as a parameter in the drawing. So that whenever the position of that part change, it will be refreshed in the drawing too.
  • you cannot put BOM position into note
  • BOM positions are generated inside repeat region table
  • BOM positions can be displayed in BOM Balloons, only
Jnithini4-ParticipantAuthor
Thanks for the response
StephenW
No, unfortunately it is not possible to use repeat region parameters outside of the table or balloons
Thanks for your response
