3-Newcomer
Display limited string lenght/text of tekstparameter in another parameter
I want to assign only the first 7 characters of parameter (string) to another parameter. How can I do that via relations?.
Creo 9
KenFarley
KenFarleyAnswer
Use the EXTRACT function.
Something like
stringResult = EXTRACT ( stringSource, 1, 7 )
You should look into the syntax for this relation function.
This should work as long as the string being used as a source is at least 7 characters long.
KenFarley
KenFarley21-Topaz IIAnswer
Something like
