Display the units used in part and mass in a repeat region.
Hello, everyone.
For Creo 8, I am setting a repeat region to generate a BOM for my top level assemblies.
Some of my concerns are:
  1. We have parts/sub-assemblies created in mm and in. We need to know the units used for length for each: parts and assemblies.
  2. For the parts that have already a mass value calculated, we need to know the mass units: kg or lbs.
I have tried what is shown in this post but it didn't work. I have already done:
  1. Activated "units sensitive" option in relations manager.
  2. Created a totally new parameter that is related mass=pro_mp_mass to be units sensitive.
  3. Called for unit according to the post (link above), using &asm.mbr... and &mbr...; same result: nothing works.
Any help will be very appreciated.
maybe tip from following article will help you.
https://www.ptc.com/en/support/article/CS129693
Can you zip the drawing and assembly and upload it?
If not the actual assembly, a sample of what you have to work with.
