Jun 11, 2019 8:32 PM UTC
Distributed Batch
I am working on a project in Creo 4.0 M090 to get a .tif file out for many of our models using the Creo Distributed Batch program.  I came across 4 topics I need to solve if possible.
  1. Is there a way to have a certain layer turned off when the Dist Batch program uses Creo?  We have a layer called THREAD that I need to turn off.
  2. I am using the No Hidden mode of each part model.  Is there a way to control the thickness of the lines of the output for .tiff files?  The default thickness needs to be increased.
  3. Does the Dist Batch program have any way to auto-crop to maximum size (boundary) of the model?
  4. Is there a way to set the default view as the standard orientation?  Many of our users do not save the models in the default view.
I’m hoping there is a config.pro entry that works for these.  I know there is a way to run a trail file with Dist Batch but that is not an option right now.
Mahesh_Sharma
22-Sapphire I
Jun 12, 2019 12:29 PM UTC
@STEVEG
Not much option to help you but you may wanna try creating a mapkey a execute that dbatch. A mpkey will help you on 1 and 4 query.
Mahesh_Sharma
22-Sapphire I
@STEVEG
STEVEG21-Topaz IAuthor
Jun 12, 2019 2:47 PM UTC
Yeah, I thought about that but I do not have time to look into that.  I have an intern to do these.  I was hoping I could make it easier.
